TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch gone?
Re: Clutch gone?
300ZMang
on April 26, 2012 at 3:14 PM
Clutch gone?
posted by HK'S Z
on April 26, 2012 at 10:35 AM
Maybe you have a slight boost leak, that affects your car's performance more as you raise the boost.
Higher boost, more leakage??
Clutch gone?
HK'S Z
10:35:55 04/26/12
Do this
Draker (Eugene, OR)
11:25:11 04/26/12
Thanks Craig! I will try that. (n/m)
HK'S Z
11:41:12 04/26/12
Easiest test: At about 60 mph in 5th, put gas pedal
zellamay
12:42:28 04/26/12
Zellamay - Yep, I had a car with a bad clutch before
HK'S Z
13:01:07 04/26/12
Re: Clutch gone? -
300ZMang
15:14:27 04/26/12
300ZMang - Been testing for boost leaks, counldn't
HK'S Z
10:49:05 04/27/12
Did you adjust the clutch travel?
Chickan
18:18:04 04/26/12
Chickan - Yes I did. It starts engaging about 3/4 of an
HK'S Z
10:29:41 04/27/12
